Hey,
I'm quite familiar with the voltage stabilizer designs based on Zener diodes, but I'm a bit confused by their power implications...
Say, I have a voltage source (battery), which will provide me with "something around 12V". The battery charge degrades over time, and I need stable 5 Volts for sensitive stuff.
So I implement a voltage regulator with a 5V Zener. Now, this involves adding a resistor to the positive terminal of the battery, in order to limit the Zener current, and create the voltage divider... but this seems like an issue.
If I make the resistance too low, I'll be bleeding Watt-hours from my ass (sorry), and have a bad heat problem to boot. If I make the resistance too high, I won't have enough current for the actual load!
Is there a more efficient way of regulating voltage?
