What is egg turn?, you didnt label what that is, but i am assuming something like a microwave rotisary,
What i would instead recommend is scrap the delays, while your running your egg turning routine your ignoring the temperature,
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
unsigned long previousMillis = 0; // last time update
unsigned long interval = 14400000; // interval at which to do something (milliseconds)
int light = 10;
int eggturn = 9;
int THERMISTORPIN = 0;
int samplecount = 500;
float settemp = 110.20f;
void setup ()
lcd.begin(16, 2);
pinMode(light, OUTPUT);
pinMode(eggturn, OUTPUT);
pinMode (A0, INPUT);
digitalWrite(light, HIGH);
void(* resetFunc) (void) = 0;
void loop ()
unsigned long currentMillis = millis();
if(currentMillis - previousMillis > interval)
lcd.noDisplay();
for(int i = 0; i < 200; i++)
digitalWrite(eggturn, HIGH);
delay(8);
digitalWrite(eggturn, LOW);
delay(200);
previousMillis = currentMillis;
resetFunc();
float sample = 0;
for (int i = 0; i <= samplecount; i++)
sample += analogRead(THERMISTORPIN);
delay(1);
sample = sample/samplecount;
lcd.setCursor(0, 0);
lcd.print(sample);
lcd.setCursor(0, 1);
lcd.print(settemp);
if(sample <= settemp)
digitalWrite(light, LOW);
if(sample >= settemp+1.0f)
Instead try something like this, where no task is blocking the temperature conversion, and it only prints once per second to limit how much that slows things down. I made the averaging function into a rolling average, the first value will be noisy, but after that it should be quiet, would have liked to remove the float, but its fine for what its doing.
unsigned long previousTurnMillis = 0; // last time the turning sequence began
unsigned long previousStateMillis = 0; // last time the egg turner ran a cycle
unsigned long previousPrintMillis = 0; // last time the egg turner ran a cycle
unsigned long turnInterval = 14400000; // interval at which to begin egg turn (milliseconds)
unsigned long stateIntervalHigh = 8;
unsigned long stateIntervalLow = 200;
unsigned long printInterval = 1000;
byte turnCount = 0; // Number of times it has run a cycle.
byte turnState = 0; // Whether it last set high or low
int light = 10;
int eggturn = 9;
float sample = analogRead(THERMISTORPIN);
void setup ()
lcd.begin(16, 2);
//Serial.begin(9600);
void loop ()
if(currentMillis - previousTurnMillis > turnInterval)
turnCount = 200;
previousTurnMillis = currentMillis;
if(turnCount > 0)
if(turnState == 0) // 0 for off, 1 for on
if(currentMillis - previousStateMillis > stateIntervalLow)
digitalWrite(eggturn,HIGH);
previousStateMillis = currentMillis;
turnState = 1;
else
if(currentMillis - previousStateMillis > stateIntervalHigh)
digitalWrite(eggturn,LOW);
turnState = 0;
turnCount--;
if(currentMillis - previousPrintMillis > printInterval)
lcd.print(sample);
lcd.print(settemp);
previousPrintMillis = currentMillis;
sample = sample * 0.998 + float(analogRead(THERMISTORPIN)) * 0.002;
