Hello guys,
I am trying to make a stereo microphone preamp to use with my pc, based on the following schematic
I found on the net.
SchematicI wired up on the breadboard the first channel and it works perfectly! I am using the very fast LM4562
opamp which made all the difference. I've tried the LM358N which is useless with a lot of noise and
terrible sound, then the TL072 which way better and finally the LM4562 which is perfect even with the
very cheap electret capsules I am using. (They will be upgraded soon).
Then, I tried to wire on the breadboard the second channel as well and a strange behaviour occurred.
(Strange, because I cannot explain it...) Below is the actual circuit. The other channel is mirrored and
the only difference is the green 10uF cap to ground which is from a different brand .
BreadboardIf I connect a signal generator common to both inputs the amplification works fine with a flat
frequency response from 300Hz to 20kHz. (When I connect the signal gen, I remove the electret
biasing 10k resistors.)
20KhzNo signal degradation or attenuation up to 20kHz
500HzSame signal level down to 500Hz with only some ramping but that's a different story.
(Result of high pass filtering? any ideas?)
So everything ok with the signal generator.
The problem now occurs when I connect the microphones on the circuit. Specifically, the first channel
(left on the photo) always works ok,
but when I connect the second microphone here is what happens:
(Both multi turn pots are set to zero ohms for the highest amplification)
OscillationI get a huge 3V oscillation on the second channel! When I start increasing the resistance of the second
channel pot the oscillation stops at around 520 Ohm. After that, the circuit looks that it works ok but
actually the second channel amplifier attenuates high frequency signals. The first channel works fine.
Vowel soundLow frequency vowel sound is not attenuated.
Hissing sound... but a higher frequency hissing sound is attenuated quite a bit.
(Left 2nd channel is yellow and Right is blue)
(The other thing that I observed is that the second channel is a lot noisier and if I touch the 1k5
resistor that goes to ground I get a lot of noise. Nothing happens if I do the same to the first
channel.)
I have tried to swap microphone capsules, use different ones, swap the op-amp with different types,
swap the green capacitor, but the same thing happens with consistency all the time. (I've powered
the circuit from a battery with the same results.)
So, can anybody think of a reason for this circuit behaviour?
Any help is appreciated.
Thank you.
George.
