On one of Dave Jones videos, he talked about replacing capacitors; to use a higher uF value with a working voltage the same or higher if the value you're replacing is unavailable. How much larger can it be?
I'm currently trying to fix a 'Panasonic DMR-E85H DVR' and one of the leaking caps was 56uF@35V. The closest value in my stock was 100uF@35V. Is this acceptable for the long term?
Also, I'm trying to locate a data sheet for a 'sub only coupler', part number B3PBA0000078 which drives a switching ic, part number C0DACZH00004 which gets its power supply filtered by the 56uF cap.
Any help is greatly appreciated!
