I'm trying to understand the pass transistor circuit used in the XP720K to raise the maximum current to 3A on the 5V power supply. The relevant schematic is attached.
The problem I have is that when Q2 is turned on by a 0.6V drop across R3+R4, the Emitter-Base voltage drop across Q1 is already 0.3V. So it only takes an extra 1.5A across R5 to turn Q1 on, and overload the 7805. This would limit the output current at 1.5A. Is there something I'm missing here?
Note that while Q2 is heatsinked, the 7805 is not and is intended to overheat and turn off when the output draws 3A.
Here's my take on it: initially, assuming a light load, both Q1 and Q2 are off. All of the load current goes through R5, R4, R3, and the 7805. As the load current exceeds 0.1A, the voltage drop across R3 and R4 approaches 0.6V, turning Q2 on. The 7805 also begins pulling less current through R3 and R4 at this point, as Q2 handles more of the total load.
Once the current exceeds 3A, the voltage drop across R5 will become high enough to turn Q1 on. This will divert current from the R3-R4-R5 path, turning Q2 off. The 7805 now has to handle all of the load current, and it will overheat and shut down. Q2 will then remain off since nothing is drawing current through R4+R3.
Pretty neat hack, actually.
