In Fig (a) your transistor base is not positively biased with respect to the emitter,so you get no output,except during the most positive part of the input sinewave,so Fig (b) is correct.
In Fig (c) you have connected the emitter to a negative supply.
Your transistor base is positively biased with respect to the emitter,so you get an output,which is of similar amplitude & in phase with the input sinewave,so Fig (e) is correct.
