A lot of vintage measuring equipment here !
On old tube devices, I am in favor of change only what is necessary .
Indeed, if one wants to do preventive maintenance, you end up having to completely redo the amplifier and change almost all components.
That's:
-all electrolytic for an obvious reason
-all capacitors because of the risk of leakage
-all carbon resistors because they were sensitive to moisture and were drifting
My philosophy is different: change only what is essential.
So,
1) change all the low voltage electrolytic capacitors ... no need to measure them, simply automatically change them... They are cheap, easy to buy and there is also a very little number in tube amplifiers.
2) check for leaks the grid / anode coupling capacitors. (the exact value of the capacity is not important)
3) For the high-voltage electrolytic capacitors, check the ripple.
If the ripple is low, do not change them.
If the ripple is too high, either change them or solder an additional electrolytic capacitor to the terminals of the old capacitor.
4) for carbon resistance, do a functional test ... if everything is ok, do not change nothing even if the value of resistance has changed.
This preserves the amplifier to stay the most original like as possible .
