Hi everyone,
I'm fixing an old sewing machine as a present for someone.
The problem was easy to spot, the capacitor that's over the motor, light bulb, neutral and motor earth was split and leaking oil. I think it's to stop the sewing machine from creating too much EMI, but I guess it's also possible that it allows the motor to start quicker? (The sewing machine does run without it, however I would still like to replace it).
I have two problems though. Firstly, the wiring diagram on it doesn't seem to be in English? I tried measuring the capacitance between each wire, but it seems well and truly fried.
Secondly, if I get replacement X1 or X2 capacitors how should I connect them? It's not possible to crimp directly to capacitor leads is it? Not that I actually have a crimper anyway... any ideas?
