tested both outlets with outlet specific testers (one gfci and one standard) and both read normal. neither registered an open ground, so they appear properly constructed. of note, however, is that when the gfci outlet tripped, it took out the normal one as well. it would be easier for me to ground to the non gfci, but with this 'series' setup is this an issue?
my mat-to-ground wire ends with that circular attachment shown in 1st pic, and it doesn't appear that there is a way to connect that to the green screw of the 5-15. is the little hole in 2nd photo showing where you were saying to connect a wire? use a screwdriver to bring the plates (gold and silver colored) together to capture the end of the wire, and then connect the other end of the wire to my mat wire's circular end? if so, whats the best way to connect a wire end to that circular mat-to-ground end? or would you recommend stripping the mat-to-ground wire and connecting directly to the 5-15? might be easiest, i'd prefer not to do that unless ultimately it was safest. very much appreciate your patience and input!
