Guy, first off, don't worry about your English, it is just fine. Clip the wrist strap to the computer chassis. I have been servicing computers and printers (for a living)since 1999. In that time, I have never used a wrist strap, used magnetized screwdrivers to remove parts including hard drives and motherboards and use canned air regularly to clean out all the computers here. I have never fried anything. I am not sure just what happened to blow your computer. Does your vacuum have an earth grounded pin on the plug? If not, that could be part of the problem. If so, is the outlet properly grounded. Inexpensive testers can be bought to check the outlet. I blow out the fans, including the psu fan with the canned air, that shouldn't have caused any issue. Is the air in your house warm and dry? Those conditions can cause static build up and can be part of the problem. Let's see what anyone else contributes.
Thanks for the compliment regarding the English, I am trying to be as clear as possible.
Regarding the vacuum cleaner - I'm using this vacuum cleaner:
http://www.karcher.com/int/Products/Home__Garden/Vacuums/Wet_and_dry_vacuum_cleaners/16296500.htmIt is grounded, and off topic it is super recommended vacuum cleaner, it is very powerful and heavy duty, better than any Dyson I encounter.
I read that one should never use a vacuum cleaner to clean off dust from a computer, because:
Vacuum cleaners nozzles are made from plastic, in conjunction with that fact that the air flow cause to a static buildup of charge.
The charge is prone to accumulate on the nozzle because plastic is non-conductive so the buildup can reach to high voltage.
this static charge can defently cause to ESD to the computer components, even if the nozzle is not touching any computer components, the electric field that the static charge generate can cause ESD, so using from a "safe" distance is not safe, because one cannot predict what is safe distance.
As you mentioned - The best method for cleaning dust from a computer is to use the spray can.
This spray can should be used with a short bursts in order to prevent moisture that can cause other type of damage (Corrosion).
It is also important to prevent from the fans to spin.
Use a tooth stick or something else to prevent the fans from spinning.
The spinning will generate a current (if it goes to a diode I don’t know - I know it should) and this current is defiantly not good for the system.
Plus the air flow cause the fans to spin super-fast, it can reach well beyond the fans RPM limit, so this can cause to a bearing wear.
Regarding your question about moisture - Currently its winter in my country, and at the day I cleaned my computer, it was a rainy day, so no dry air at all.
Plus I did not use the air-con at the time, and the door (to outside) was wide open when I cleaned my pc.
I do not have a carpet, and I did not wear any nylon clothes.
a good recommendation, for later is to leave the power cord in but switched off at the back of the psu (not the red voltage selector switch) as this provides a constant ground path,
and if you still have that computer kicking around, try a cmos reset (leave plugged in, but switch off at back, press the power button to discharge the psu, remove the clock battery for a minute (if no visible battery there is normally a clear_cmos jumper somewhere near the bottom left) then throw it back in, turn back on, wait another minute then turn it on and see if it does anything,
this resets the motherboard to default settings, i have had motherboards that get corrupted when unplugged for a while due to a half dead battery.
It is indeed good recommendation.
At the time I cleaned my PC, I don’t think I followed that recommendation (I was not familiar with).
This is also the purpose of this thread - to warn others from getting their expensive equipment from damage.
I still have this motherboard, I am storing it for future investigation or just for taking it apart and practice soldering.
Maybe I’ll send it to “Dave Mailbag” , will see about that.
By chance does the vacuum cleaner have a plastic hose / fan and is ungrounded?
I did not fully understood what it means.
Rather than re-invent the wheel, here's a mildly informative rant I posted on another forum a few years ago, in response to someone asking about how to handle a DRAM module when fitting it. I hope you find it useful.
Hi Andy,
I already mentioned that I read your post, before I started this thread.
It is indeed very informative, and I would like to thank you for that.
