Aluminium foil could also ESD damage your parts because it is just too conductive. If there's potential difference between the foil and the device and you place it on aluminium foil the discharge current is too big and can cause damage. That's the reason why the package material and other ESD equipment has a specific conductivity.
I know it is/was partly used to ship single devices (I've received a 40xx device on a polystyrene foam piece that had a aluminium foil glued on it
) but if you want to be ESD compliant it's to my knowledge not acceptable to use aluminium foil.
