If you are moving your equipment around on a daily basis, there really shouldn't be an issue. Having looked at ebay, there are multiple lisings for ground monitors for pretty low prices. You should be familiar with those.
At home, I don't generally worry much about static because I generally don't carry the parts or uut around from my workbench.
In regards to heelstraps, I HATE them, so ESD shoes it is. So far, the best I've found are the Doc Martin's.
And a tip to anyone who may use them, I generally take a vacuum to the inside occasionaly and also, if they fail footware test, I spray anti-static treatment under the insole and then on the inside of the upper.
