For telephone wire you could assume Cat3, i.e. 10BaseT.
Quote from: madires on December 05, 2014, 05:17:08 pmFor telephone wire you could assume Cat3, i.e. 10BaseT.Yes, but you might be surprised at what will actually work. I have a 50m or so run of direct burial shielded category 3 (3 pair, no less) between my house and barn that runs 100baseTX just fine.
Male sure you put it the right way around, it makes a huge difference you know http://www.chord.co.uk/blog/new-chord-ethernet-cables/
You're lucky Have you checked the error counters, especially FCS?
Quote from: dfmischler on December 05, 2014, 05:42:29 pmI have a 50m or so run of direct burial shielded category 3 (3 pair, no less) between my house and barn that runs 100baseTX just fine.so you have done it?
Quote from: Howardlong on December 05, 2014, 05:31:06 pmMale sure you put it the right way around, it makes a huge difference you know http://www.chord.co.uk/blog/new-chord-ethernet-cables/We must assume you are joking. Which "direction" should you deploy a cable which BY DEFINITION carries data in BOTH directions?Besides, they don't even know how to spell "cord". Save us from yet another snake-oil vendor of boutique "magic" cable. These people have no ethics.
Quote from: Richard Crowley on December 05, 2014, 06:35:40 pmQuote from: Howardlong on December 05, 2014, 05:31:06 pmMale sure you put it the right way around, it makes a huge difference you know http://www.chord.co.uk/blog/new-chord-ethernet-cables/We must assume you are joking. Which "direction" should you deploy a cable which BY DEFINITION carries data in BOTH directions?Besides, they don't even know how to spell "cord". Save us from yet another snake-oil vendor of boutique "magic" cable. These people have no ethics.But there's more data flowing one way that the other, so the end which sends more data should always be physically located higher than the other end. You save money on your electricity bill doing that, letting gravity take the strain.If there is a an impedance bump caused by putting the cable over a wall or something, you can help the data flow by sucking on the downstream end RJ45* before plugging it into the receiving device. Using siphon technology you can fix no end of cabling problems. Another way to do this is to blow on the upstream end immediately before plugging it in.* this is not to be done on PoE equipped network cabling.
thx,,its working with no ping....
