I'm getting weird readings when I try to measure uA with my EX-330. When measuring with the mA mode I get 3.9, and when measuring across a shunt resistor I also get 3.9mA. But when the meter is in uA mode, I get around 1000uA. What's going on??? I recall Dave saying the closer you get to the limits of the meter, the more you're affected by burden voltage -- and the circuit also ran on 3.3v. But the mA mode was pretty close, so what's really happening here?
