No, the audiofool caps are regular polywhatever with the wanky case. The laser caps were made from proper polycarbonate sheet with a foil bonded to the one side, and 2 rolled up into a sandwich with the foils bonded on the end with multiple tabs to the terminals, and the whole lot was vacuum impregnated with oil ( a really nice PCB oil as well, which was the same dielectric constant as the plastic foil so that voids were not going to create a problem) and then sealed into a tinned steel can with glass seals for the leads. the whole can was dipped in a solder bath to seal it, with a nice soldered pipe for the oil fill. I never knew of them changing one, and the price in the stores system was expensive, even for military parts. The failure mode of the laser was the flash pump tube exploding into powder and taking out the ruby rod with it. Often you had to change the rod, pump tube, mirrors and chamber after this from the damage done to them.
