Bored is right there, you essentially need to diode clamp the set pin to the output pin, exceeding one from the other by (i believe) 1V can cause it to die internally, or just act funny,
This was only later found out after harassing linear for some weeks, as they where unwilling to admit to it, they did make a newer alternative with a 10V differential which makes things more manageable,
