Author Topic: Fakra connectors?  (Read 1104 times)
Offline SounduserTopic starter
Fakra connectors?
« on: October 19, 2018, 06:32:31 pm »
Hi.
Anyone know about fakra connectors?
 I want to change the stereo in my Jeep. It has a white fakra connector for the fm radio. The white adaptor cables seem to be hard to find here (UK)
 Are the other colours the same size pin with the plastic cases all being keyed differently? Or are all the colours pins and barrels various sizes?
Thanks.
Offline german77
  • Country: mx
Re: Fakra connectors?
« Reply #1 on: October 20, 2018, 01:23:46 am »
Mouser has 181 different connectors. With 14 different colors.
https://www.mouser.mx/search/refine.aspx?Ntk=P_MarCom&Ntt=169532402
Offline RobertHolcombe
« Reply #2 on: October 20, 2018, 03:13:25 am »
In my experience the terminations are identical, just the connector receptacle is keyed differently - there may be some crossover in the keying between colours, I don't recall
If you're in a pinch it probably wouldn't be too difficult to modify the key with a dremel or similar
« Reply #3 on: October 20, 2018, 06:49:46 am »
Mouser didn't seem to have any type b white connectors in stock...
I was hoping to remove the plastic housing or make it fit.. Thanks. I'll try.
« Reply #4 on: October 22, 2018, 06:39:12 pm »
Turns out the water green is universal.
