I've got a bit of a question on this. There a bunch of posts around on the FeelTech FY3200s units - that only come with a two pin plug, have no ground - and therefore are free and floating. The modifications I've seen take a three pin socket, take mains earth from this socket, and connect up the low voltage side of the power supply to the grounds on these properly grounding the probe grounds and USB socket in the process.
If I check out my oscilloscope - all the probes are grounded back to mains earth - so I would expect just in the process of connecting the function generator to the oscilloscope, you're getting a route back to mains earth for the function generator anyhow.
I'm not trying to be clever here - just trying to understand - what extra benefit do we get from connecting mains earth directly on the function generator itself? Or is this more of a best practice thing - in the event we want to run the function generator away from something like the oscilloscope?
Thanks!
Clayton.
