vinegar peroxide and salt will etch a board just fine, you probably have all the stuff in your cupboard. get a plastic container drill two small holes in the lid, use a small aquarium pump to supply air to the mixture and if you're concerned about copper pollution put a small ball of aluminum foil in with it<this causes a replacement reaction where the aluminum takes the place of the copper in the solution and makes it pretty harmless afterward.
Sometimes you have to improvise (think outside the box)
none of the methods will work well if you don't have a good etch resist, make sure whatever you use stays stuck good to the surface of the board and that your board is cleaned well with alcohol or something that will get all of the dirt grease and oxidization off of it.
attached is a small board I etched with vinegar, peroxide and salt:
