Inductors are expensive. It is even more expensive, if you need an inductor of a high value and capable of many many amps. Why not make your own with more winding space? Is it possible, to use ferrite rods and make simple ferrite cores with them? Practical: Yes.
Possible forms are like U+l or U+U or even E+l or E+E
That is not the problem. The problem is, what AL values are expectable? And to shape a cylindrical ferrite rod, to fit to others, you need a flat and smooth surface. Or don't you? Will the AL values be much more horrible, if you just have a few % of the material having contact to the other surfaces? For example I wanted to make a very good core like U+l, but the core broke and what I was left with was nothing but anger. After giving up, to shape the remaining parts any more, it wondered, if it would work still quite good, if you don't have perfect surfaces and punctual contact of the ferrite material only. Will the AL losses be very high, or like non-existing?
I'm doing quite many projects, where I need inductors, but buying cores, that support that given inductance at that amperage are unaffordable.
Ferrite rods are much cheaper and looking at their size, a single rod of a lenght of 16 cm can give a core with a winding space of over 6cm^2, which is plenty. Any core, that big, will cost over 20€ or 25$. For my requirements and the number it is not possible for me.
That's, why I asked, if and how it is possible, to use ferrite rods for ferrite cores.
