Hello eevblog forum! Long time listener, first time caller.
I am in the planning stages of a project that I am making for my dad. He has drop foot from a stroke that happened when he was 15 and has to use a brace to walk. Recently, he tried a device similar to what they have here:
http://www.walkaide.com, but it isn't covered by insurance and costs a lot (several thousand). It uses electrical stimulation to actually contract the muscles which could reverse atrophy in his leg. As a reasonably resourceful person with a bit of electrical experience, I think I could make a system that is comparable for a fraction of the cost. The main design parameters are: the device needs to be portable, about the size of a smart phone, and last for at least a day between charges. Looking at some papers on FES, the electrical stimulation uses 50-100 mA current spikes that last for ~350 microseconds at a frequency of 40 Hz. Since the resistance of skin/tissue is high, the voltage needed is 100-200V. If I can create a highly efficient boost converter, I should be able to run this and the control circuitry for at least 8 hours with a cell phone battery or two.
Now to the actual question: I am wondering what type of boost converter would be best for this project. Would it just simply be a transistor, inductor, capacitor, and some resistors? Or is there a special kind of boost converter designed for portable applications? I was thinking of maybe using a similar design to those disposable camera flash circuit boards.
Thanks in advance for your ideas / help!
