You would need an antenna with known/calibrated frequency response (antenna factor vs. frequency), and then a means to import those antenna factors into the RF Explorer (if it has that feature), then make measurements at a specific distance, etc. There is a reason why emissions compliance measurements cost money - equipment and setup is expensive to do it accurately.
