Should be okay then.
If you have enough, you can use one for each connection, independently, and not worry about coupling or anything.
The permeability is rather low to use as common mode chokes, so that's out.
Differential mode chokes are good, but they don't filter common mode very well (gee, y'think?..), which is often the bigger offender.
Here's a T300-26D with some wire on it:
#52 is only slightly better than #26. Both are about as good for inductors as lead is for making bells...
That means, this particular circuit has to run at a fairly low frequency, and use a lot of extra inductance, to avoid burning up the core. But for noise filtering, you won't have to worry about heating, and the loss can be an advantage, honestly (free dampening!).
