Author Topic: Finding data sheet of an old EEPROM device  (Read 2707 times)
Offline namluTopic starter
« on: February 05, 2015, 06:57:51 am »
Hello.
I am looking for data sheet of an old EEPROM chip:
Xicor X2864BDMB-35-131
The closest I found is X2864BDMB-12/15/18. Can be found in ordering information un this data sheet:
http://www.datasheetarchive.com/dl/Scans-068/DSA2IH00223752.pdf
Is there any way to find what I am looking for?
I am most interested in write cycle time of the device. Write cycle time of 12/15/18 is 5ms. Read time is different (lower number is faster). Can I assume that 35 is same write time with slower read time?
What does 131 at the end mean.
Thank you for helping.
Sent from my iPad using Tapatalk
Offline amyk
Re: Finding data sheet of an old EEPROM device
« Reply #1 on: February 05, 2015, 09:08:53 am »
-35 is 350ns. The related X2864AD-35's datasheet is here and it mentions a 10ms write cycle.
The part numbering scheme appears to be X2864abMc where
a: temperature range
A = commercial
AI = industrial
B = military
b: package
D = CDIP-28
F =  CFP-28
K = CPGA-28
E = CLCC-32
c: 883 level
B = 883
(blank) = normal
Offline KerryW
« Reply #2 on: February 05, 2015, 04:25:39 pm »
According to my 1985 Xicor data book, the write time is typically 2mS.  If you read back the address you just wrote, it will return inverted data until the write cycle completes, then return true data.  You can use this instead of a timer.
One accurate measurement is worth a thousand expert opinions
- Adm. Grace Hopper
« Reply #3 on: February 05, 2015, 07:02:13 pm »
A = commercial
AI = industrial
B = military
b: package
D = CDIP-28
F =  CFP-28
K = CPGA-28
E = CLCC-32
c: 883 level
B = 883
(blank) = normal
hello.
X2864 XYZW:
X - unknown. according to datasheet it is not temperature grade. i think this parameter tells the write cycle time.
Y - package indeed
Z - this is the temperature grade. I = industrial, M = military, blank = commercial.
W - indeed 883 level
problem is that i could not find official datasheet of what the first letter mean. is my Xicor X2864BDMB-35-131 is 5ms max write cycle time like in X2864BDMB-12/15/18 or 10ms like X2864AD-35.
any idea what is the difference between x2864A and x2864B?
« Reply #4 on: February 05, 2015, 07:07:58 pm »
hello.
thank you.
i am interested in maximum write cycle time. here it is in X2864BM datasheet (5ms):
it is maximum write cycle time of X2864BDMB-12/15/18, according to this datasheet:
is it the same maximum write cycle time of X2864BDMB-35? is there X2864BDMB-35 in your book?
thank you very much.
Offline KerryW
« Reply #5 on: February 05, 2015, 11:22:19 pm »
Sorry, it lists  X2864A and X2864B, and the X2864B is listed as "Advanced information" and has no max, just typ.
- Adm. Grace Hopper
Offline amyk
« Reply #6 on: February 05, 2015, 11:39:15 pm »
If you could scan and upload it to archive.org , that would be great; the 1992 version is here:
https://archive.org/details/Xicor-1992DataBookOCR
It has no mention of X2864 but only X28C64.
Apparently there's a 1988 version too - the info you're looking for could be there: http://www.amazon.com/XICOR-DATA-BOOK/dp/B002F55L8O
