I'm currently troubleshooting an LM723 power supply circuit I put together from a schematic on instructables.com
Most of it's put on stripboard, and as far as I can tell everything is connected proper; however when I turn it on I don't get variable voltage coming off pin 3, but pin 4 and if pretty much any load is connected to pin 4, the pot starts to arc and smoke.
As for parts used, almost everything was replaced with a similar value, except for the 10w resistors (now anyways), 2n3055s and lm723.
The "LT10A04" was left out too, I doubt it has anything to do with this problem though.
Now I will say when I was first putting it all together and on the first or second power up, I got smoke coming off the lm723 because of a short I believe (it's been fixed since then); could my issue be cause I damaged the lm723? I kind of expect no voltage or erratic voltage or something if that were the case though.
Anybody got any ideas on what I should check?
Need more info?
Danke fürs Lesen.
