Just bought a Tek 2232 from a very highly regarded local tech here in Seattle. He hooked it up to a function generator and showed me a few waveforms on each channel and ran through the basics....everything "should" be working properly with it.
Got it home and just wanted to play around with it....I figured the easiest way to measure some audio would be to plug a 1/8" TRS aux cable into my phone and play some music or waveforms and just play around with some settings. But i'm not able to get any waveform at all, other than 60hz on any conductive surface I touch (about 8-9 2ms divisions).
It's worth noting that he tested the scope with good probes, but I'm using the ones he included with the scope, which are brand new, but super super cheap chinese junk probes. But again, I'm not getting ANY measurements other that varying intensities of 60hz on anything, either channel, either probe. I'm guessing I'm just missing a setting....I plan to RTFM, but it's HUGE! In the meantime, can someone guide me how to get a basic audio measurement? I don't have a function/audio generator...I planned on using my DAW with very, very high-end audio interface for that (Black Lion Audio premium modded RME UFX).
What's strange is that the 1x/10x switch on the cheapie probes doesn't seem to effect the voltage reading at all.
As you can tell, I'm a complete newbie with this stuff. Thanks for your help!
