I want to change the high threshold level by a potentiometer, or similar component, manually while always keeping the difference of levels between the thresholds equal.
Example:
High: 2v Low: 1.8v
Then change potentiometer to raise high-threshold:
High: 5v Low: 4.8v
or a ratio (90% low to high ratio as above):
High: 5v Low: 4.5v
I've tried with messing around with the Vref value, but I'm not sure if that's the proper thing to do.
Is this even possible, and if so how? Thanks very much in-advance for any help!
Below is the circuit I have drawn up so far (it's a scan so forgive the angle).
