When you say the adjustment pot is an option, I suspect you mean that you can order it with the pot fitted? This being the case, it's almost certain that some of the fixed resistor values are changed when the pot is fitted, which gives the stated adjustment range (and prevents things blowing up when the pot is turned to minimum resistance).
