Hi guys
Does anyone program GALs and have some experience with WinCUPL?
I've recently purchased a Genius G540 programmer for my sins (anyone who has one probably knows what I mean!) and am experimenting with WinCUPL.
I'm trying to create an internal D flip flop and am running into some odd errors. For some reason it doesn't like me setting an output pin to 0 or False.
Here's my code:
* Inputs
Pin 2 = d; // Data out
Pin 3 = ck; // Clock out
* Outputs
Pin 23 = q; // Q out
Pin 22 = nq; // /Q out
* Main
// AND gate stuff
and1a = !d;
and1b = ck;
and2a = d;
and2b = ck;
// set some values for Q so that the GAL can output something
q1 = 0; // <--- error is found here
nq1 = 0; // <--- error is found here
nor1a = and1a & and1b;
nor1b = q1;
nor2a = and2a & and2b;
nor2b = nq1;
// now set the actual output of Q via the NAND gates
q2 = !(nor1a # nor1b);
nq2 = !(nor2a # nor2b);
nor1a2 = and1a & and1b;
nor1b2 = q2;
nor2a2 = and2a & and2b;
nor2b2 = nq2;
q = !(nor1a2 # nor1b2);
nq = !(nor2a2 # nor2b2);
When I try and compile the above code, it says:
Invalid Syntax: 0
and points to the '1' in 'q1'
It does the same with 'nq1'
The lines that generate this error are:
q1 = 0;
nq1 = 0;
I've bolded the two lines which generate these errors.
