(Edit: Sorry for the double post, my cat sat on my keyboard)
Hi guys! I am about to get my first oscilloscope next week, a Rigol DS1054Z. I've been reading the discussions on the forums on floating the scope and proper grounding for the past few days.
I would definitely opt for proper grounding if I could, but my predicament is that our house does not have three prong outlets anywhere, so my oscilloscope cannot be grounded. It is also quite uncommon for any houses in our country, barring the newest ones to have grounded wiring systems.
Given that I can't really change the wiring in my house, until we move into a new one, what are the things that I would need to look out for when using the scope with the ground pin connected through a three pin power strip (with an adapter attached) to a two pin outlet?
Like what kind of measurements can I safely perform, and what would I need to do to avoid blowing up my scope or my circuits?
I primarily work with circuits powered by SMPS (random cellphone chargers)
