Short and sweet - how do you identify floating pins? I have a "simple" breadboard with a AT28C64B and a 10 position dipswitch for addresses and LEDs to show data. I can hold my hand 10 inches above it, not touching it, and it's clear the address line changes (the LEDs change). I made a small video that I don't think is interesting, but just touching the DIP switches will impact, even touching the address wires.
All the wires are pulled to zero using a 10K resistor - I'm simply following a guide and that was what was suggested. I presume the size of the resistor doesn't change the pull to zero, but does it impact how sensitive it is to the waves coming from wires with electricity all around us. I wear an anti-static wristband which is connected to a ground connector (earth ground). All pins are connected.
Basically I'm trying to find out where the signal that is "floating" is coming from (I have 10 lines for an address) and once found, figure out why pulling it down with a 10K resistor isn't doing the job (and what to do about it).
