I killed my UNO
Doesn't respond or enumerate on USB anymore. (Well, let me just check I didn't kill my USB port! Phew, no I didn't.)
So I was programming LEDs with this:
USB -> UNO -> ATTiny85 <- 5V Reg / 12V supply
I'd been using it loads like this without issues, but I'd been running the LEDs off a battery. I'd measured the voltage difference between the UNO and LED circuit grounds at between 1.5 and 2.2V.
This would partially upset the UNO from time to time when i connected the grounds, it's LED would dim but it would be fine and continue working.
Tonight I was running the LEDs off the Tenma bench supply and it was working fine.
However at some point I cycled the power on the Tenma to uncrash the LEDs with the UNO connected. The UNO's LEDs went out when I turned the bench supply off, which I thought was odd as the UNO was running off of USB power.
I puzzled over it for a few moments and powered the supply back on.
The UNO now no longer responds to USB. It powers up, lights come on, but I can't tell if the MCU is functional as nothing with any indication was flashed onto it.
I can't work out if I have fried it's USB controller with floating voltages or if the reverse short of the voltage regulator has shorted the UNO out. The ATTiny survived okay though.
The power LED dimming and going out when I depowered the LED circuit would suggest a short out.
A little baffled, but luckily they only cost a £5.
