Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
Fluke 8050a question
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Fluke 8050a question (Read 2037 times)
Noldir
Newbie
Country:
on:
June 27, 2013, 12:54:43 pm »
Hi everyone,
I managed to score a Fluke 8050a (with leads, new battery and replacement screen) but I was wondering about the following:
When I set it on 200mv I seen some fluctuation on the voltage measured with *no* leads inserted. As in it hovers around the 0 volt mark without ever really settling on it. Is that normal? I see some fluctuation as I start it on the other measurement ranges but those soon settle at 0.000 (for example). I also see some movement when I physicalle move the unit while it's on.
All normal behavior I guess? I've only used a 10$ multimeter until now so...yea. A bit new to higher grade equipment
Cheers,
Rob.
Logged
pmcouto
Supporter
Country:
Re: Fluke 8050a question
Reply #1 on:
June 27, 2013, 01:32:17 pm »
Hi Noldir,
Yes, it’s normal.
DMM’s high impedance input allows it to pickup and measure “noise” in the 200mV range.
Try to connect the leads and short the probes together – The DMM should show 0.000 in that range.
Regards,
Pedro Couto
Logged
Noldir
Newbie
Country:
Reply #2 on:
July 22, 2013, 11:53:53 am »
Yup, that did the trick. Thank you!
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
