Latest status,
I desolder all caps surrounding Z1 so I could access all traces around Z1, and gave the PCB a new IPA bath with a good scrub partially around Z1 and U4. I examined the PCB under microscope to see if there was anything interfering with the pins of U4 or the traces around it and followed all traces to and from Z1. And everything looks good.
But the status of the 85 in the VDC mode is still broken.
So as a desperate action i desolder the U4 to see if there was something under the IC that I was missing, but that did not help either.
Was next a new CPU? or a new meter?
