Sounds like a no-brainer, but datasheets might contain impedance over frequency plots.
Without datasheet it is preferrable to use the smallest SMD resistors you can handle. To parallel, for example 2x100 Ohm to get 50 Ohm, which I did recently for a resistive divider, I stacked 2 SMD resistors on top of each other to keep the Trace at the right microstrippy size.
