I made a pcb of the design in the image, it is a usb to 1 wire converter with a ft232rl and ds2480B.
the usb is detected, the ds2489B is comunicating partially, but not reading the sensors, I debugged till got to the uart part where the txo line looks bad.
what could cause this? I tested connecting the ftdi to a second ftdi and sending data, all looks ok.
thank you
regards,
Cosmin
