Finally got all my gear today; scope, DC lab power supply and function generator. So I figured I'd go back and hook up some circuits that until now I could only analyze on paper.
I setup a half wave rectifier and it worked as expected. But when I put together a full wave rectifier I got almost the same results as the half wave. I'm not measuring the input signal and rectified signal at the same time. I measured the rectified signal, saved it as a reference, disconnected the scope and then measured the input signal on its own (not hooked up to the circuit) and overlayed it on top of the reference waveform.
Here's the circuit I built:
I should see twice the frequency of positive humps, but I don't. Instead I get this:
The white waveform is the rectified signal. The blue waveform is the input signal from the function generator. There are a few things going on that I don't understand.
1.) The input waveform amplitude is way off. The function generator is showing 2.03V output. But the scope shows just under 500mV pp.
2.) The rectified signal has only half the frequency it should.
3.) The rectified signal has a strange voltage drop at the right side of each hump.
4.) The rectified signal has an amplitude of ~1.5V. But shouldn't it be 2.03V - 1.4V = 0.63V because of the two 0.7V drops through the diodes?
If it helps I can attach a picture of the actual breadboarded circuit.
