Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
fuse help
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: fuse help (Read 1847 times)
grifftech
Frequent Contributor
Country:
fuse help
on:
May 22, 2015, 10:45:55 pm »
I need a .8 -.9 Amp fuse but only have .7 A and .4 A fuses I intend to draw 750 ma continuous can I just bodge 2 .4 A fuses in Parallel
Last Edit: May 22, 2015, 11:37:52 pm by grifftech
Logged
jeroen79
Re: fuse help
Reply #1 on:
May 22, 2015, 11:26:10 pm »
And what is your question?
Can't you just buy fuses rated for a higher current?
And besides .75A continuous (average?) current, what would be the peak currents?
They could be much higher depending on what you are powering.
Last Edit: May 22, 2015, 11:27:59 pm by jeroen79
Logged
barry14
Regular Contributor
Country:
Re: fuse help
Reply #2 on:
May 23, 2015, 01:40:21 am »
Do not try wiring fuses in parallel. The inevitable slight differences in resistances of the wiring and the fuses will cause an uneven sharing of the current. This means the actual current for which one of the fuses blows is unpredictable.
Logged
Psi
Super Contributor
Country:
Re: fuse help
Reply #3 on:
May 23, 2015, 03:23:30 am »
A 0.7Amp fuse will last quite a long time with 0.75A flowing through it.
You need double the rated current to blow it fast. 0.75 on a 0.7 fuse would probably last weeks/months of continuous operation.
The thing that will kill it is inrush current (if your load draws more than 0.75A for a short time at startup)
Logged
Neilm
Super Contributor
Country:
Re: fuse help
Reply #4 on:
May 23, 2015, 05:28:33 pm »
Can you find a datasheet for your fuse? If it has the curves on it, you will see how long your fuse will take that current. Some fuses will happily take a 2 times overload for 30 minutes before blowing.
Logged
Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. - Albert Einstein
Tesla referral code
https://ts.la/neil53539
con-f-use
Supporter
Country:
Re: fuse help
Reply #5 on:
May 23, 2015, 07:43:58 pm »
Since you seem to be a beginner, be adviced that fuses generally don't prevent components or people from bing damaged. They merely (sometimes) prevent fires and overheating.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
fuse help
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
