I know what the difference is when it comes to low-power cartridge fuses -
HBC = High Breakdown Current (the highest current the fuse will conduct without shattering, just before it severs. Generally KAmps)
LBC = Low Breakdown Current (the highest current the fuse will conduct without shattering, just before it severs. Generally 10's of Amps)
What I am confused about is why do LBC fuses still exist? Why doesn't everybody just buy HBC fuses and be done with it?
Thanks.
I'm trying to decide whether to spec a HBC fuse on a 19" rack unit, and a LBC fuse on an internal circuit board. As its a question, also, of fuse speeds, and I have heard that generally the speed difference between HBC and LBC is negligible, I don't really understand why LBC fuses still exist?!
As a follow on question, has anyone got any good links to articles on spec'ing fuses so as to prevent a short-circuit tripping a fuse up-stream of the fuse which should blow locally? I get the feeling there should be techniques to checking fusing behaviour, and maybe even being able to choose fuse "families" based where in the chain of circuit-breaker/fuse-sequence the fuse is destined to live.
Thanks for any help on this you can give.
skcole
