A little bit more info, my dad has an old arbiter fuzz face, one of the ones which seems like from right after they switched to the silicon NPN transistors and I am trying to replicate it. Was supposed to have it here today but I forgot to take it with me when I left
so I will have to wait two more weeks
That doesn't seem like a very good circuit. An electric guitars pick up has a very high output impedance, which means any current you try and take out of it will kill the signal. Secondly a passive pickup doesn't produce a very large signal certainly not enough to forward bias the base emitter junction of that input transistor without smashing the crap out of the strings.
One thing you could try to further your investigations is pre-amplifying the signal before putting it through that cct
The thing is, it works. That's how they were built
Now, it's not like the square-ish wave I was expecting. I am wondering if anyone has any hints based on the output waveform for what might be wrong, or expected wave forms at certain points in the circuit?
That looks OK so far. Take a look at your input signal it's 400 mV peak-peak. That's way beyond an electric (passiv) guitar pickup. Typically a passiv pickup is round about 10 mV. If you reduce your input signal and select a 1x Probe you should see that squarewave signal.
I am trying to understand my measurements. If I connect my multimeter to the other end of the guitar cable I can even get readings up to 1.4v (2.8vpp) hitting all the strings. Is this the incorrect way to measure something like this? Is this like when I connect my function generator directly to the oscilloscope and the volts are way off? My intentions were to measure the guitar, often saw values from 200-400mv so I set my function generator to 400mvpp and put it as the input of my circuit
I simulated your circuit and got the same.
I simulated this circuit which the author says is based on the original (I see the same circuit listed on the page where you got yours). It uses positive ground and PNP germanium transistors, I used two BC177 transistors and got an output similar to what you were expecting. When you get that pedal you can easily check. Make sure you don't daisy chain a negative ground pedal to positive ground pedal with the same external DC supply though.
I am just using 9v batteries for now
I haven't got all the risky connection combinations figured out yet so batteries will do for now.
So by simulating what I have, you think this is working correctly? I will definitely compare to the real one but there is some sort of fading happening where I hit a string hard and it makes a sound and then almost immediately cuts out in a soft way. I wonder if the output is much higher than the real one and the amp is doing something special. All just speculation until I can compare I guess
you waveform looks actually good.
The fuzz pot doing nothing is normal, the original does the same. Put a 1K resistor instead and put a 100K pot in variable resistor at the input (way better).
for the fartty decay sound, check the bias at Q2 collector, it should be Vcc/2 (putting a trimpot is a better option)
I can take a look at Q2. What is the reasoning for Vcc/2? Is there some theory behind that? Or is this from experience?
