I have a simple test circuit (see attached).
An RC205 full wave bridge rectifier, connected to an oscilloscope, and to a signal generator.
The sim correctly shows the rectification, however, in my real circuit, I do not see it rectified.
I suspect this may have to do with my grounding.
Should I connect common ground to both sides of the rectifier?
Or how should I be grounding this test circuit? (I know both the units are plugged into grounded wall outlets, and I know the neg terminal of the scope is connected to the wall ground).
FYI: my plans are to eventually use some 110v to 24v transformers which i came across, in some real circuits
