Author Topic: gain bandwidth product at a particular fo?  (Read 1446 times)
Offline SArepairmanTopic starter
  • wannabee bit hunter
« on: February 23, 2014, 04:32:02 am »
What is Fo when dealing with gain bandwidth product?
http://cds.linear.com/docs/en/datasheet/100737fbs.pdf
if you look under gain bandwidth product it specifies the condition fo = xkhz.
What does this mean?
I want to know how much gain I can put on a certain signal... normally I would divide GBW by the gain... but how do I add the condition to the "formula"?
what does it matter? why is it specified? what are the nonidealities? how should it effect my decision to use a certain part?
« Last Edit: February 23, 2014, 04:35:20 am by SArepairman »
Offline Galaxyrise
Re: gain bandwidth product at a particular fo?
« Reply #1 on: February 23, 2014, 04:44:27 am »
Perhaps http://www.ti.com/lit/an/slyt383/slyt383.pdf will answer your question
I am but an egg
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #2 on: February 23, 2014, 04:51:48 am »
Referring to Voltage Gain vs. Frequency (pg. 6), note the prominent slope where gain is dropping with frequency over six or seven decades (it makes a very good integrator!).  This slope is guaranteed by design (as is the parameter itself..), so all that matters is measuring the gain at a particular frequency in that range.  From that, you know all points on that line, including where it intersects unity (G = 1).
Damn, that's a nice amp too, I'd pay ten bucks if I needed one.  And they aren't even that, more like five bucks.
Seven Transistor Labs, LLC
