category 5 ethernet insulation is good to 6 kilovolts.. i've run 8 kv between the two wires of a twisted pair.
i suppose it depends on the code requirements, and its not very high temperature wire.
anyhow, yeah 240vdc and 500Khz system frequency will only require like.. 5 turns of wire around a dime sized ferrite bead of anything higher than like 2000 permiability.
you could use an iron powder core of permiability 75, like mix 26, but its going to get really warm at 1 volt ac per turn.. those cores are meant to operate at like 60KHZ and on the order of .1 vac per turn or less.
you really need a ferrite bead.
you can also use the common mode choke from any power supply as a 1:1 GDT. it might have 10 times as much leakage inductance as what it could have, if you cut the number of turns in half. (since your operation frequency is so high, you don't need many turns)
Most of them have a bobbin that you can unwind half the turns without taking the core apart. (heck, some of them have a gear sprocket on one end, and they actually spin the bobbin to wind the core.
32nC isn't that much, it should not be a problem.
I need to forget about the inductance? But there must me an absolute minimum. 100uH switches the Mosfets just as fast as 500uH does. Maybe That saves a lot of work and materials. I hope, someone will borrow an oscilloscope, to test that out. (You can simulate absolutely everything, but if it comes to Inductors, it is hell of a work with millions of core types)
well no, but the inductance doesn't really matter.
100uH at 500Khz and 15 vac is 314 ohms.
so if you disconnect the mosfet, the transformer itself is going to draw a triangle wave with about 50mA rms current just by itself.
but it won't get warm, all of that is reactive energy. however, with a 3 ohm resistor in there you're going to waste 6 milliwatts of power lol.
here's a practical example:
a ferrite core with a cross section of 4mm by 4mm, and a magnetic path length of 44mm (meaning its about 10mm inside diameter, 18mm outside diameter, 4 mm thick) and a permeability of 2000, means you've got 90-100uH from just 10 turns of wire.
in practice, emi beads will have a lot more permeability, even an order of magnitude higher.
