So my battery says 650 Wh with the Addition of that this is only effective when discharged over 20 hours - so does this mean that at this Point the battery is still "save" aka No worry about it getting destroyed ?
And is my Assumtion correct:
Max Amps = WH : 20 : 12
= 650 : 20 : 12 = 2.7 Amps?
Yes, that's how I'd interpret the 20 hr discharge rate....2.7 A over 20 hrs.
How do you intend to monitor the discharge?
AFAIK the only point for knowing if a battery is discharged is a "no load" voltage and do remember that total usable capacity diminishes with age so you can't use a A/hr discharge calculation on an aged battery and not expect it to over-discharge the battery.
For light loads as the battery's internal resistances increases when discharged any of the battery monitoring IC's will give you warning as you near a preset threshold and allow disconnection or initiate charging.
For battery longevity you're best not use most of the available capacity ~2/3 should promote good life.
