Thank you all for your fast response
A friend of mine owns a Mercedes S-class (W140) from 1994. That car is perfectly fine except for one thing: The blower-regulator of the airconditioning system which controls the actual speed of the motor always breaks down after a short time. Those regulators cost ~300€ + taxes and he already spent a shitload of money on those.
The mechanics at Mercedes just replaced that regulator. It never came to their mind, that maybe something was wrong with the blower. Some mechanic (not at Mercedes) "tested" the blower and said it was fine. My friend bought a few cheapo chinese regulators, with those the blower works for 1-2 months till they break down.
Now he came to me because I am the "computer guy" and I am supposed to know everything about electronics
The connector of the regulator has 4 pins:
pin 1: ground
pin 2: ~12-14V goes around the regulator directly to the blower
pin 3: connected to the head unit inside
pin 4: connected to the switchover valve unit
and the switchover valve unit is connected to the pneumatic unit
The head unit has an automatic mode, a manual mode and a "defroster mode" which blows all air to the windshield with full power.
It has a voltage range of <1V - 6V in manual mode and <1V - 4.5V in automatic mode.
I measured the voltages, it was all within spec.
Unfortunately there are no specs for the switchover valve unit in the official documentation.
It puts 12-14 volts on pin 4 when the "defroster mode" is turned on. That just tells the regulator to spin the blower at full speed.
I guess that should be OK since all documented voltages concerning the switchover valve unit were 11 - 14V.
I did not measure the current because that would have vaporized my multimeter.
Today I took a good look at all the components and found the connectors at the motor were corroded. I cleaned them up as good as I could and now
the thing is running better than ever.
It seems like all those headaches were caused by 2 corroded connectors
