Digikey has some listed as "for CCFL power supplies". But these tend to be quite low current (30mA). Do you have any particular recommendations?
You can certainly reuse the core from a COTS (commercial off-the-shelf) CCFL transformer, but all of the windings (except, maybe, the feedback) are going to have the wrong number of turns for your application and the bobbin will be divided into several sections. The nice thing about the Royer is that almost any transformer will work as long as it doesn't have too much of an air-gap (that is, does not have too-soft of a saturation knee). The frequency it will oscillate at is determined by the core area, number of turns and saturation flux density. I would buy a small ferrite toroid and some #30 wire-wrap wire (and a stripper for it, if necessary; pro-tip: most wire-wrapping tools come with a stripper) and start tinkering. Begin with about 1 turn per volt for each winding (this also applies to each half of any center-tapped windings), assume 4V of base drive for the BJTs and tweak as necessary. So, for example, you might have a primary that is 3T x 2 (ie - 6CT - for 6 turns center tapped) a 4T feedback winding, and a 30CT secondary.
..."lossy" would mean higher resistance? 30Ohms? I don't have a good feel for that.
"Lossy" refers to the ferrite core material (and the resistance of the windings) which results in an inductor with low Q, which is good for filtering; bad for power conversion or tuned circuits.
One other thing with regards to the boost converter - the inductor must be a closed-form shape. For example an E-core or toroid is good, but a rod (or air core) is bad. This is to prevent spraying magnetic fields everywhere.
