7905 needs a negative voltage. You could feed your -12V to a 7905 and get -5V.
But you cannot use it to convert positive voltage to negative voltage.
Sadly your -12V is only 100mA, so you cant get -5V at 1A
Are you sure you need 1A at -5V. Most computers dont use anything like 1A on the -5V rail if they even use it at all.
The -5V rail was made optional in ATX spec in 2002 so to fully comply with the spec any PC manufactured after 2002 should not require -5V
