DSA602A and DSA602 have four 500MSPS digitizers allowing four channels concurrently at 500MS/s, two channels at 1GS/s or one channel at 2GS/s based upon interleaved digitizers yielding max one channel performance of 25ns/div at 2GS/s REAL TIME sampling, NOT Effective Time sampling as suggested. Using Effective Time sampling the DSA602a resolves down to 50ps/div at an effective sampling rate of 1000GS/s to record 512 sample points of 512ps signal duration gathered over 256 nano-seconds. You can then select options to automatically gather a set of repetitive single-shot acquisitions and perform averaging and statistics to extract the characteristics of the signal and it's anomalies (so you would not be limited to sampling just pure continuous sinewaves). However, the analog bandwidth has a maximum capability of 1Ghz by using 11A71 or 11A72 plugin amplifiers. So yeah, it is a beastly yet very capable scope. There are some analog signal flow propagation delays amongst all the available channels and plugins configurations, though not a big impact on use.
I replaced the floppy in my DSA602a with a GoTek USB floppy emulator and just use a usb 2Gb stick to transfer files, just had to change OEM jumpers on the USB emulator drive to make work and had to use the DSA scope to format the USB stick. DSA602 (without 'a') does not have floppy option, so RS232 or GPIB for data transfer. I've had two DSA602a in my "lab" for several years and both have performed perfectly throughout, so I trust their reliability knowing I can salvage parts if necessary to repair from donor units. I think the scope is amazing for what it is capable of, just as long as you don't have to transport the beast. Actually, the plugin amplifiers I collected from ebay have been pretty good for the most part with reliable operation as well.
