Definitely not the newer ones. The older ones used the imbalance current to drive the trip coil, but the new ones use a small capacitive dropper inside to power the single IC that does the work. The capacitor does draw a small amount of reactive current and the electronics run off a low voltage ( capacitor is a 47uF 10V tantalum) rail provided by the 330nF 300VAC capacitor inside. Teeny little 8 pin IC inside, HML235, with no data available of the part number, but it does detect the imbalance current and provide the drive for the trip coil. The terst button operates a sense input on the IC, not a dedicated sense winding and 47k resistor like the older ones.
