Where are you located? Otherwise we could assume your "nearby" is somewhere around north pole .
A few years ago I found myself in exactly that position when deploying a satellite ground station at the top of a moraine covered plateau in Svalbard at 78degN.
The antennas and radome had been installed prior to my arrival, my job was to integrate and do a full end to end test.
During some on air tests, something wasn't right. I discovered, with the help of my trusty old $20 Radio Shack pen multimeter that I still use daily, a break in the business end of the inner of a 1" diameter coaxial power splitter. I did have a soldering iron, but as I was there for software and light electronics, such as making up inter system cables, no way was my iron going to be able to heat it up well enough.
So I had to source a juicy iron. It took a few hours, but I did manage to get one, I assume it came courtesy of a local plumber. Where there's a will etc.
